Is my master cylinder bad?
HaveSomeJoe
66
Jun 3, 2007
Portland, Maine
Well I've been removing and installing the pedal assembly getting really frustrated because I don't know whats wrong.
FIRST, the nut on the threaded portion of the shaft was really loose when I removed it, so I tightened it, welded it, didn't melt and bushings or anything like that. I put it back in and had to adjust the rod all the way out and the clutch would still only engage BARELY, right on the floor.
I took it out and inspected it, the lever springs back all the way like it should with no play, even with the brake pedal.
When I put it in the car, it still was good all the way up until I tried to screw the master cylinder rod into the c-bracket. As soon as I did that, the inch of play came back, and it was a squeaky inch by the way. I tried to watch the end of the shaft where the weld is when I wiggled the inch of play and im pretty sure it was moving like it should.
I did this work after I made sure the slave and master were in working condition, and today the slave cylinder gushed out fluid under the boot when i checked so that must have blown out while i was trying to drive it the first time after i welded it.
What does this sound like??
sounds like you need to stop welding the thing because the heat will melt the seal inside of the cylinder, just buy a new one bro
About this product:
Part Number: LMC158
Weight: 1.31 lbs.
Warranty: LLT
Application: With cruise control
Pricing:
$41.99
Autozone
or even a master cylinder rebuild kit
Clutch Master Cylinder Kit
< Home | Shopping
Brakeware / Clutch Master Cylinder Kit
for a 1990 Eagle Talon
Related Parts
Clutch Slave Cylinder
Slave Cylinder - Kit (Clutch)
About this product:
Part Number: 22305
Weight: 0.15 lbs.
Warranty: 0 MO
Pricing:
$18.99
Availability:
Store: Not Available
Online: Ships within 2 business days
    • The_Partout_Spot
    • The_Partout_Spot
  • For sale Garage clean out
    • 92GSXtacy
