FIC 2150 Owners Please Read - how to wire in
Jon91TSi
942
13
Jan 1, 2004
Bernville, Pennsylvania
Just installed my 2150's last night, I will be using the supplied hardwire pigtails, however no instructions were given as to how to wire these into the factory harness. If someone that could chime in that has done this (specifically on a 1g), your help would be very much appreciated!:thumb::thumb::thumb:
Thanks!
Jon
Injectors are a solenoid so wiring those pigtails in either way will work, just as long as the wires you cut at the #1 spot are ran in the #1 spot you'll be good. :thumb:
...or if you've got OCD like me, the positive (red) comes from the resistor pack and the negative (black) goes to the ECU (since the ECU completes the circuit to ground).
I bet you didn't think it would be that easy, did ya?
:dsm:
:dsm:
I kinda thought that might be the answer but I figured id better ask and be sure. Thanks a lot!
