F@%K ME, 40 counts of KNOCK
treckin
35
Aug 30, 2008
Turlock, California
OK, just found out that my car in knocking like a bi***... This is my first log...
Looks to me to be lean, and definitely the next thing to buy is a wideband + v3 ECMlink.
Mods:
14b stock @ 17psi
Evo3 exmani, ported collecter + runners
510 'yellow top' injectors PUMP NOT REWIRED yet, have everything, just wanted to log first
4" FP intake
2g MAF
Punishment racing open dump o2 housing
'flex' back ebay exhaust (previous owner )
EGT
Boost
Hallman pro rx MBC
head with less than 2000 miles on it, ARP headstuds + Mitsu composite HG
40 counts of knock is unheard of. I believe you either need a knock sensor or new lifters.
My FWD had a bad knock sensor when I first bought it, and it was doing the same thing. As soon as I'd roll the throttle on around 2300-2500, it would pick up injector pulse or lifter noise and MAX OUT the knock count. At 40 counts, it was pulling so much timing that it felt like a non-turbo.
May need a knock sensor also I would hurry, and do that rewire.A 2g maf on 510's will be on the lean side.
I was thinking that 510s would be a bit lean @17psi, but am still learning so I wasn't sure. 550s/560s would solve that problem.
