parker4
- 52
- 19
- May 14, 2009
Florissant,
Colorado
The cars fuel mods:
Wideband with egt and a boost sensor.
Walbro hp 255 (not rewired).
-8an ss lines from pump to fuel rail.
high flow fuel filter.
aeromotive fpr.
Safc 1 (5 knob).
stock 450cc injectors (850cc sitting in room)
bosch o2 sensor (new)
The turbo is a scm6152e.
2.5 inch exhaust.
The situation:
When I start my car my afr sits around 14.5:1. After about 30 secounds or so the afr's begin to climb steadily untill they reach a mixture of 21:1 which is the highest point that can be read on my wideband. I've completely maxed out my safc to 30+ at 800 and 2400 rpm. My afr will move back down into the 13:1~16:1 area as I fluctuate the rpm's. The car just started so is fairly un-tuned and does not have an eprom ecu. I turned up the fuel pressure from 36psi to about 43psi and noticed that the afr's will stay around a 14:1 mixture a little longer but eventually begin to climb back towards 21:1. I did not do a boost leak test but ran over all the vacume lines and didnt find anything unplugged. My ilde vac is around 21.
I do not plan on making any power right now and that for the turbo's size pushing any amount of boost is just asking for my car to go boom. I do plan on retrofitting the ecu soon, but this is my dd so I need to be able to drive it now.
I dont understand why the car gets so lean at idle. I wouldnt think that at just idle the turbo would be pushing so much more air into the engine that i could'nt tune for it with my safc. So do I keep uping the fuel pressure until I'm a little more incontrol? And if I do that at what point will the injectors begin to fail? Or do I put the 850cc injectors in and hope to be able to tune them with the 5 knob safc?WTF
Thanks in advance for any help.
aeromotive fpr.
Safc 1 (5 knob).
2.5 inch exhaust.
The situation:
