Extremely Lean Air/fuel Mix
TORONTOTALON
37
Jan 18, 2005
Toronto,Scarborough,
I have a 1g 2.0 n/t and my air fuel mix is very lean i no this because i pulled my plugs and they are white and my e test failed because of high NO gas and the is caused by lean air fuel mix i was wondering if neone has any quick guess at what it could b
things i have done
fuel injecter flush (actual one the u hook up to the rail)
replaced mas
repleaced spark plugs
air filter
p.s the car feels like it runs great but with power loss i dunno what this could be
Could be a failing sensor, fuel filter, pump, preturbo/post mas intake leak, to name a couple. But be sure its a real problem before you go trying to fix it. A logger would be nice.
i have no check engine light and i just replaced the fuel filter not to long ago
what sensor on the motor could make such an impact on the air fuel mix
well see if the sensors were a problem the check engine light would come on, a sensor that could actual confuse it would be your air flow sensor,air temparture sensor, and barometric pressure sensor.now listen this is a MAYBE not a for sure answer to your question but ill do some more reading up and see what i get.
