extreme psi install hardware
Jiggalude
284
May 14, 2005
Lancaster, Pennsylvania
Did do some searching. I'm planning on buying pretty much everything from extremepsi.com to install my 16g. I saw that the 7cm turbo gasket to the exhaust manifold isn't very good. So I'll pick up the OEM one. As far as the bolts and gaskets for the exhaust manifold, or exhaust side of the turbo etc., are they good?
Nothing?
Yes they are good. They are thin and get soft and swell a bit with the heat. I have been running them on my turbos even the 7cm gasket. I have yet to have a problem or leak.
The problem with the 7cm gaskets are the cheap ones like E-bay stuff. I think DSMGraveyard has an OEM evo 3 gasket for cheap if your interested. Call Jon the owner of DSMGraveyard at (269)226-4463. Hes a really cool guy to deal with. I go to him for every last little part that my DSM can and will ever need.
