420A Exhaust system cat delete and muffler delete
Ethenp23
132
7
Jun 24, 2021
Midland tx, Texas
Would a 1995 eagle talon sound good with a cat delete and muffler delete but keep the 2 resonator ?
i had a gst with a 3" from the from the DP all the way back, it was strait pipe except for a high flow cat. So no muff and no resonators.
i think it sounded good. the turbo is all the muffler you need.
if were talking 420a, the car sounded good with a gutted cat, stock mid-pipe (which includes the resonator) and a tsudo rear section with straight thru muff.
I say try it and see how it sounds.
Yeah the previous owner took off the cat and left the 2 resonator and muffler so I was just gonna delete the muffler replace it with a small test pipe and weld a spec d exhaust tip
it all depends on what you like. i like it loud. most people listen to the radio but i'd rather listen to the exhaust.
Plus i like to piss off the neighbors.
Well looks like the neighbors are gonna have problems in the near future 🤣
Do you know if TSUDOs cat backs are still available for 420a? I purchased one 5 years ago it was the best exhaust for my 420a
i doubt it, i bought mine back in 2003.
i would try looking for used ones. i just checked and couldn't find any place that sold them new.
I have a 420A 95 Talon with Megan Racing Headers, Megan Racing full exhaust, Cat Delete with Test Pipe installed. It sounds good and is not raspy at all. The Megan Racing Muffler has built in actual resonators half way back and also has a silencer that can be removed easily with three set screws, so you can adjust the sound a bit to how you like it.
just noticed you said 2 resonators , there is only 1 on a stock exhaust.
the silencer is for sneaking up on people. If someone hears your car pulling up a few times they will always know your pulling up by the sound of your car. So you put in the silencer to make it sound different and people will have no idea its you until they see you pull up. A must have if your a stalker or if your GF is a huge slut.
Yeah I know like I said he took the cat off there’s just a muffler and a resonators obviously he replaced the cat with another resonator because the cat is gone
ah.. ok.
if you remove stuff to where the exhaust is dumping under the car, make sure and put a turn down at the end of the pipe. Some thing like this, so the exhaust will be directed toward the ground.
