- Ownership Status
- Currently Own
- Year
- 1995
- Model/Trim
- Eagle Talon N/T
- Drivetrain
- FWD
- Transmission Type
- Automatic
- Build Type
- Street
- Mods-Bolt-on
- Cold Air Intake routed to lower front bumper access
- Mods-Engine
- Megan Racing Headers, downpipe, CAT Delete Test Pipe Install, Megan Racing Full Exhaust. Accel Ignition wires, high performance coil, Cold Air Intake to the Front Bumper, EGR Delete, Intake Manifold Removal, Cleaning, Replacement, Fuel Injector Replacement. Replaced stock headlights with Spyder Halo Ring Headlights (No I did not remove the front bumper and yes I was able to remove and install that hidden bolt). Timing belt replacement with water pump, idler pulleys, and tensioner replacement. Alternator and relay bank replacement. Engine Sensor Replacement (Cam, Crank, water temp, O2, MAP, IAC, TPS, Knock).
- Mods-Handling
- Konig Illusion 17" X 7 wheels, 40 mm Offset, 225/50 R17 Tires. Fits with no rubbing or modifications (for those that were wondering).
- Background
- 1995 Eagle Talon ESI. It was in rough shape when I purchased it, two years of work in my garage and it looks and runs great.
