2G Exhaust questions for GSX
CertifiedBot
33
10
Nov 8, 2021
Oneonta, Alabama
I have a 95 GSX and have been working to get it running.
I had to drop the tank and realized the exhaust is going to need a new flex pipe and the muffler is welded to the car, not on a hanger. I’d like to fix the muffler hanger and mount it correctly, and I think I’m going to put 2 v clamps on the pipe unless that’s a stupid idea.
I was curious if there’s any reason to mess with/change the down pipe also. What are some common upgrades for the exhaust and why? It’s a 2.5” pipe, is that the stock exhaust size?
If you have the ability to, why not? That’s what I always say LOL. I think stock is like 2.25” but don’t quote me on that because I had a NA galant to begin with.
I changed every singles flange on my car to VBands to keep everything consistent. Also the places I put them I can swap out setups whenever I want. No more gaskets and ease of installation 👌
Really depends on your plans for the car. If you plan on keeping it stock and driving it as the factory intended, then there's no real reason to change the exhaust beyond what is necessary to fix problems. Yes, 2.5 is stock.
If, however, you plan to increase hp and performance, make the change to a 3" turbo-back exhaust system. You won't see or feel much (if anything) just by making that change, but it sets you up for maximizing other performance mods. Increasing power means increasing the air/fuel charge in the combustion chambers... so having a larger exhaust allows your engine to breathe better. Too large isn't good (you need to keep the velocity of the moving air to maximize exhaust scavenging), and too small is restrictive, reducing max air flow through the turbo and in through the valves.
Exhaust systems can be fine tuned to maximize engine efficiency and power output, but that is not for the street as the fine tuning has to do with a lot of engineering, power bands, rpm running range, turbo size and type, etc. etc. etc. For the street, a 3" exhaust for performance on our cars is the way to go.
'Twer I you, and with no specific plans other than getting it road worthy, I'd do exactly what you're saying - just fix the flex pipe and muffler and leave the rest alone. If the $ value of the car is important to you, keep it stock (or return it to stock). Parts are getting hard or impossible to find, so the classifieds on here are golden. You can also hit up @jerseygsx as he often has stuff for sale.
