4gfun
Supporting VIP
- 2,012
- 56
- Dec 10, 2007
Ask Me,
Virginia
So my intermediate pipe ripped in a perfect place to attach a cutout. I don't care about noise, so I wanted to put a cutout between the cat and the muffler as a clamped cutout makes a very cost effective solution in this case. The existing cat is a hi flow catco and the muffler is a magnaflow. The existing exhaust size is 2.5"
How much less power will I make with this setup as opposed to a 3" setup with a muffler? (mind you either would be catted)
I can't imagine there would be a huge difference if any. I ask because I read that a 20g at higher boost is a no no with a 2.5 inch exhaust. This is why I went with an E316g but want to know if a 2.5 inch catted exhaust with a cutout would work out fine with a 20g at higher boost or not.
Thanks
Thanks
I meant you don't have to try to tune for the best scavenging effect, that bigger is usually better.
. They are more expensive and go bad quickly. Mine doesn't seal anymore and rattles loudly. But minor things that can be easily over looked for the performance gains. I have my cutout connected to a stock catback so just driving around you would never know my car makes over 600whp until I open the cut out
