keltalon
Supporting VIP
- 3,478
- 976
- Jun 29, 2003
Luthersville Ga, Atlanta,
Georgia
Well for the last couple of week I have been having this problem with oil blowing out of my valve cover ports and getting all over my engine bay. After doing much reading I was thinking maybe I have a blown piston ring or something else seriously wrong. I did a compression check and everything looks exellent 165 across the board. leak down test also was good.
No vapor coming out of valve cover at idle nor any vapors out of the dipstick tube. Spark plugs looks clean with no oil buildup what so ever. I tap for more ventilation on my valve cover and even installed a greddy oil catch can this stopped the oil mess on my engine bay. But another problem developed I began to fill up the oil catch can pretty quickly. I knew something wasn't right. So I started to read extensively online join all kinds of turbo forums trying to seek answers. After many hours reading and digging I found on one site a similar issue and how he fixed the problem.
He suggested that his baffles under his valve cover had lost his sealing properties and suggested that i check mine. Lo and behold
problem found and oil blowing all over everything and filling up catchcan a thing of the past. So if you are having a similar problem and you engine is health check you baffles and make sure they haven't come loose. Here is a video of what I am talking about this was taken before problem was fixed.
<iframe width="420" height="315" src="http://www.youtube.com/embed/o7rx2WzmLAw" frameborder="0" allowfullscreen></iframe>
problem found and oil blowing all over everything and filling up catchcan a thing of the past. So if you are having a similar problem and you engine is health check you baffles and make sure they haven't come loose. Here is a video of what I am talking about this was taken before problem was fixed. <iframe width="420" height="315" src="http://www.youtube.com/embed/o7rx2WzmLAw" frameborder="0" allowfullscreen></iframe>
