Another possible oil pressure relief solution??
DraginX
101
Nov 21, 2002
Moncton,
I've been doing alot of searching and thinking on how I'm going to finish off my balance shaft removal. While thinking about the best solution to do the removal I thought of a way to relieve some pressure this removal causes. If you use the stock rear shaft (oil pump) when you cut it there is a oiling hole going through the center. I am going to weld this hole shut, but I was thinking couldn't you relieve some pressure by drilling a small hole 1/16" or so to start. Same with the front balance shaft, it'll be completely removed (bearing also) then a plug with a simular sized hole drilled in it will be taped and installed. After that a plate made up to block off the hole. I can't see how this would cause any problems as it'll just be dumping oil back into the bottom end and if the hole stays small enough it'll still have pressure.
I would like to see a good discussion on this like the size the holes should first start out as, pros and cons that it could cause, etc... I don't expect anyone to do this as I'll test it out myself but would like some serious feedback.
I make a stub shaft for the oil pump, and leave the other shaft in place without a belt. I've never had a higher than normal oil pressure in any engine with this method. By doing it this way I only delete 1 bearing journal.
I was reading through my post and have the front and rear reversed, I'll be editing it properly. That is what I meant is the oil pump gear shaft as the one cut and welded with a tiny hole drilled in it.
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
