PC5505
- 48
- 0
- Oct 13, 2005
Seattle,
Washington
I have a 1G and was planning on running 650cc injectors on my E316, in fact I already bought both the injectors and a 2G MAS because I don't want to hack.
I've read several posts about running a 2G MAS and 550's on a 1g, and that it requires very little tuning because the 2G sensor tells the stock ecu that less air is flowing through it than there actually is. With stock 450's it would be lean, but if you have the 550's it actaully gives you a ballpark tuning base. If that's true, then would the same hold true for an EVO MAS in a 1G equipped with 650's?
I ask because I can appreciate the smaller dimensions of the EVO MAS vs either the 1G or 2G parts and also since I've never tuned before and haven't quite decided which tuning route I will be going with I'd like to start as close to where I'll end up as possible should I end up piggy backing(safc/neo) for purposes of keeping my timing reasonable.
Also, does anyone know if DSMLINK supplies settings/maps for use with an EVO MAS? I know they can just be set to run a 2G MAS pretty easily but doubt there is a plug and play setting for the EVO sensor. Maybe the upcoming version will? I'm sure no one makes a chip for it unless you custom order.
