ECUflash Evo 8 ECU idle issues
97gst_spyder
2,262
16
Sep 1, 2008
Lakeland, Florida
I never had a single idle issue with my car with the stock ECU. After swapping to the Evo 8 ECU the idle is fine unless the A/C was on. Once I swapped to an auto trans I have idle issues if its not in drive.
So if I did not use A/C back when my car was a manual, the car idled at 750, no issues. If I had the A/C on for more than 15-20 miles, the idle would be much higher when the A/C was off (1-1.5k). This would stay high for awhile then go back to normal. This would happen repeatedly, not random.
Once I went auto, the car idles damn perfect when in gear (R,D,2,1). When in P,N the car idles at 1.5k and throws a CEL for Idle control failure.
I swapped ICS again (both tested fine, black ISC's), harness is fine.
Anyone else have this issue? Or something like this?
Its driving me up the god damn ####ing wall.
No one else with an Evo8 ecu and auto trans has this problem?
