Evo 3 Oil Filter Housing Question
TAL0NTSi
161
Dec 26, 2010
Westerville, Ohio
Hey guys,
I'm looking into getting an evo 3 OFH for my talon.My question is, are there enough ports to run an oil cooler, oil feed, and an oil pressure gauge? I've seen people talking about all three of these separately, but maybe someone has some pictures showing which port you can use for what. Thanks in advance.
Hey guys,
Go with the EVO9 OFH if you want all of the provisions rour referring to. Look at my build thread and you will see the differences and what is needed.
You are spreading misinformation just to get you post count up. It does not have everything the stock 2g has.
Yes it does have everything the 2g ofh has. Granted 1 hole has to be drill and tapped but the hole is there. That's my fault for not mentioning drilling and tapping. Spot for oil feed, spot for oil pressure and a spot for dummy light. Everything on a 2g Ofh.
Next time instead of just saying something is misinformation maybe you should state why or make a correction instead of just being a smart ass. We're all here to learn and share not to be tools to each other.
Thanks for the help guys, seems like the EVO9 OFH is the route im going to go with.
