eprom?
andybar
Feb 13, 2011
albany, Ohio
i have a 91 tsi and was wondering how i go about tuning my eprom ecu? Also at what point to i have to change my tune as far as upgrades? i am new to dsm all around so anything would help.
If you are going to "tune" your EPROM the. You need a burnable chip or go with ECMlink or dsmap.
You tune it with DSMLink. You have to tune at anything over 15 psi.
This question has been asked many times. may want to use the search function to avoid getting flamed.
That's a little misleading. For the STOCK turbo then yes, anything over 15psi WITH a new fuel system.
Tune when you put new injectors on or mess with the fuel pressure or even fuel type (pump going to ethanol). Also tune when you increase airflow, change piston compression, cam lift/duration, timing, etc.
Good catch Liquid. Yes you will need to upgrade the fuel system at that point.
i am pretty sure i do... i have an ecu out of a 90 and out of a 91 the 90 has no chip in the bottom right corner and the 91 does
