Please Support Kiggly Racing
Please Support Rix Racing
Street Build 97 GSX PROJECT
Ownership Status
Currently Own
Mitsubishi Eclipse GSX
Build Type
  1. Street
Speed Density: Mitsu-Style Omni 4-bar Map & GM IAT connected to MAF with harness
Holset WH1C in BEP .55 housing
DNP exhaust manifold
Tial 44mm Vband external wastegate
FP intake pipe with K&N filter
Innovate MTX-L Wideband - Sensor placed in front o2 location, using NB sim with ECMLink
Powder Coated Valve Cover, Shaved lettering with -8 AN fittings and custom baffles installed,
Gamble97 Custom Catch Can
Punishment Racing FMIC
Coil on Plug Setup
Greddy RZ BOV
HKS clear timing cover
1G black top CAS with Sheridan 1G in a 2G harness
Walbro 255 with STM rewire kit
FIC Fuel rail
FIC 1120cc Injectors
Aeromotive AFPR
Aluminum Radiator with shroud and slim fans
Full SS clutch line
SRS Full 3" Exhaust
Carbon fiber Hood
HKS Turbo Timer
Avid Racing Street Motor Mounts
Pioneer Double DIN TV
Auto meter C2 boost/vacuum gauge
Auto meter C2 oil pressure gauge
Mods-Engine
FP2 Cams
Skunk2 Cam Gears
Fresh stock rebuild 6-bolt block with 2G head
BSE
ACL Race Bearings
Mods-EMS & Logging
ECMLink V3 with Speed Density
Mods-Drivetrain
Shep Stage 3 Trans
Rear LSD
ACT Street lite flywheel
ACT 2600 Clutch
KYB GR-2 struts
17" Wheels with Z rated tires
Z-Speed Front & Rear strut tower bars
Parts Wishlist
Next up is Paint job
Background
Spent close to a year building my motor with no car to put it in. Did this on purpose because I knew if I had a car waiting for it then I wouldn't take my time with motor and would probably cut corners. Finished motor a few months ago 5/2014 and bought this 97 GSX on 8-6-14. Already dropped the motor in. Now I'm just checking over things and waiting till I buy ecmlink v3 before I attempt 1st start.
As of 12/4/2014 the car runs great and I've put a lil over 600 miles on it so far.
2/10/2015 - Switched to Speed Density
  • Like
Reactions: IronLion08
95GSTowner
Comments
More in 2G DSM
Share this Vehicle
