Eprom or Non-Eprom??
The eprom ecu has an extra chip on the board that can be removed and replaced by a tmo chip or the like. As you said also the dsmlink system requires the same. I have researched this quite a bit and it seems that there is not a real performance difference between the eprom and non-eprom ecu. The only way to even know if you have or do not have one is to look at the ecu itself. If there is a letter "E" on the ecu then it is eprom and if some other letter than not likely. Unfortunately if you have a 1990 like I do you have to open the ecu itself and check for the extra chip.
Is there any particular reason why you wanted to know what the difference was?
Nothing wrong with just plain curiosity.
OK, Im have a small e at the beginning of the part m#. Tomorrow I will try to see the bottom right corner to see what letter is there. I need to gt a keydiver chip in an EPROM ECU. I don't tkink I am qualified for DSMlink. Afterall I'm using webTV!! Thanks, Mark
