2G EPROM ECU question
Solace Lost
78
Jul 28, 2011
Lagrange, Georgia
So I just got some 660 denso injectors and a stage 3 keydriver chip for them. Today I got my ECU socketed for the chip.
My question is, can I put the socketed ECU in the car without installing the 660's?
I don't want to run it like that as I have another non EPROM ECU in the car now. I just want to make sure the car will crank and run after the ECU work. I would hate to have to put in the new pump, injectors and ECU, just to have to take them all right back off.
Thanks!
You can run the socketed ecu with the stock chip, and stock injectors. If you put the keydriver chip in with the stock injectors if will run lean.
I did the socket at a local computer store a few years ago and they burnt the board. But everwhere is different so the only way to find out is to plug it in and try to crank it.
