engine turning over but not starting?
indians32
Feb 24, 2009
Fort Wright, Kentucky
99 eclipse 2.0 nt, 5 spd. 420A
just did a t-belt and water pump replacement. i got the car back into time and everything lined up damn near perfectly. there was less that 1/16 inch difference in the markins on the cams and crankshaft. now yesterday when i finished the repair i tried to start it, it turned over but wouldnt start. found oil on the spark plugs (3 out of 4). so i am assuming that is from a blown valve cover gasket. I took out the plugs and dried them off and let them sit over night. i went to put them in today and see if it would start but still same thing turned over but wouldnt go. i tried giving it gas and starting it in gear and neutral just to see if that made ay difference. the rpm isnt moving at all. i havent replaced the vcg yet, could that be the only problem? should i get new spark plugs? since its the 420A i was told that the valves are less likely to bend een though the t-belt broke, so im leaning away from that. any information or ideas would be great thanks.
Since you broke the t-belt, your best bet would be to do a compression test or a leakdown test to see if the valves are bent and stuck open. I had the same problem when I got a supposedly good head from a friend. #1 and #4 valves were bent and not seating properly, so the car wouldn't start.
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
