Engine Stalls at Idle
thejones
Dec 12, 2010
Long Island, New York
I have a 96 eclipse non turbo. It runs fine other than it will occasionally stall at idle and will try to cut off when driving, but never does. (the dash lights will flicker on for a moment and the car will jump) It will also cut off when slowing down at at light. I have done a complete head gasket job timing belt ect, IAC sensor, cam and crank sensors, fuel pump, tune up also...plugs, wires fuel and air filter and it still does the same thing. Any help would be appreciated.
I did the timing to perfection...ecu is a possibility also the vacuum leak. What is the tuning device?
My little n/t ran like shit when the rear O2 sensor had ripped wires coming out of it.
As soon as I put a new one in it ran perfect.
Check it out.
