Dave1288
- 0
- May 23, 2006
North Granby,
Connecticut
my 2g eclipse is smoking bad when i get on the gas, but at idle it still smokes alittle at start up, its blue ish smoke by the way and i was wondering what u guys think is the problem
. If no shaft play = good seals, then I agree with the compression test (as I stated above).
, if can you recommend any piston/ ring combos and rods. this motor is going to be rebuilt for high boost. if you have any recommendations let me know thanks Dave
