Engine revs to redline when started after 6 bolt swap
black95tsi
Apr 17, 2005
Royal Oak, Michigan
I just completed my 6 bolt block swap but now when I start the car it immediately goes revs toward the red line. I shut it off before it gets there though (about 5500rpm). I checked my throttle cable as well as my throttle body and neither are stuck. I also switched my TPS with a used one I had sitting around, that still did not solve the problem.
Before the swap I did not have this problem. I only have very mild mods that are in my profile.
Cole
Thank You! It seems to be working, but only half way. When lowering the motor i accidentally broke the cylinder just in front of the battery. Is there anyway that I can remove just the cruise section of cable and leave the box until I can get the non cruise throttle cable?
