6 bolt swap question
tlcoolj
119
14
Mar 1, 2004
Baton rouge, Louisiana
I am getting ready to put in my 6 bolt and i have a question regarding the 1g cam sensor. Do you have to have some sort of logger to install this and get the car running correctly? I read what RRE has to say about ajusting the baseline timing, but i was just wondering if there was anyother way around using a logger since i don't have one. Or if anyone is in the indianapolis area and wouldn't mind helping out, that wouldn't suck
No you do not need a logger with a 95. Your car should have a plug that grounds the timing to 5 degrees. All you have to do is ground the timing and then use a timing light to check timing at the crank. If it's off, then turn the CAS until it shows 5 degrees.
Go to www.vfaq.com and click on the engine section. You'll find two vfaqs on how to adjust timing. One of those will have an illustration as to where the plug is. I don't personally know where it is since i have a 97 and i use dsmlink to adjust timing. ;)
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
  • For sale 2g Clean title
    • FirstTimeDSM
