TSG59_Steve
- 717
- 2
- Jun 27, 2006
Dunlap,
Illinois
I want experienced opinions on the things I am looking at. Also, I would like to know the best places to get these items (So far I have found the best prices at Forced Performance, Extreme Psi, Bonehead Racing, and Import Evolution).
First, my plans/dreams/goals. I want a streetable 300+ horses.
Before my engine spun a bearing I was looking into getting a FP Big T28. Now I want to get my hands on the Big 16g Forced Performance has on sale right now. It says it is rated for 380hp. Questions on that: Should I get it ported/clipped? I want to run 25psi on this thing. My fuel upgrade plans: Walboro 190 (I've read that is enough for 16g's but is it enough for 25psi?) 650cc Injectors, and I will either get a SAFCII or I might be getting DSMlink. I will be purchasing an XS fmic as well.
Now for the rebuild questions (note: this is my first rebuild, any and all tips/pointer/suggestions would be appreciated, oh and YES I am going to rebuild my 7bolt):
First: The spun bearing was pretty horrible, like completely GONE. I have pictures but they are on my phone and I'm too lazy to put them on here. Do you think the metal shavings from the bearing would cause damage to any other areas in the engine (besides the obvious crank and rod)? Particularly the head or turbo? What kind of work should I do on the head? I am trying to do a somewhat -cheap- build. I want to get it hot tanked at the least.
I want to get: Eagle H-beam rods; ARP head, main, and rod studs/bolts; ACL Main/Rod bearings; Balance Shaft Removal Kit; Prothane Motormounts; DKS cams; and a Cometic HG. Is the Cometic headgasket too much for my plans? Should I just get the Mitsu OEM one? Also, I am sooooo confused on the spraying the HG thing. From what I read I SHOULD spray it?
What other things should I replace? (Waterpump? Oil Pump?) The timing belt I had before the bearing was practically brand new... should I still get a new one anyway? I want to clean out the engine bay in my car as well, any suggestions on what I should use?
I'm excited. I am going to wash/wax the car just so it looks good in the garage. I am going to take apart nearly everything and clean/paint it (black) so that it doesn't rust and looks clean.
