Engine Priming
4.5 Qts is where you need to be at with filter. Now, you're one Qt. over. Oil pump isn't primed in which that needs to be done first after a rebuild.
I think I can take about a quart and a half out, throw a half in the top end, and turn it over without the plugs to move the oil through out?
I did prime it from the pump.
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
