priming the engine
spectr019
254
Oct 28, 2004
East Lansing, Michigan
So I just got new turbo on and tomorrow I'm finishing up torquing everything. But I need to konw how to prime the engine before I actually start it to get some oil through the turbo. Can anyone help me out real quick and let me know how I go about doin that? Thanks a lot.
Ben :talon:
An additional method is to pull the fuse labeled "Moteur" in your main fuse box near the intake. This has the same effect as the above method and is much easier. Crank it over as recommended above to prime the turbo and you should be all set.
Hope that helps,
Andy
  • For sale 4G63 Groden alum rods. Set of 4 with ACL bearings
    Groden aluminum rods. Set of four. 22mm small end. With ACL race rod bearings. Locating...
  • Wanted 1g Harness
    Wtb 1gb fuse box harness
    • 92AWDHX40
  • For sale 2g 2G Water Pipe
