forcefed86
- 1,007
- 14
- May 23, 2006
wichita,
Kansas
Trying to help a friend out with his car. Basic problem is we build around 5psi at 5k and 14ish by 7800. Started out with a 16g, just installed a garret 57mm turbo today w/ new external WG. No change.
Basic run down:
6 bolt motor
Unknown mileage on forged internals.
Just replaced head gasket.
272 BC cams (installed straight up factory gears.)
garret 57mm t3 turbo .70 ar (wastegateless)
New t3 OBX manifold, no leaks or cracks (yet anyway)
external gate
3" downpipe no exhaust
No boost leaks.
Compression tested 150-155 on all 4 cyl. (not a leak down tester)
Good oil pressures.
Tuning with jakal SD. AFR's in check mid 11's in boost 14's cruise.
Factory BOV
Have tried blocking WG off completely, no change in boost press.
Completely blocked off BOV ( no change)
No coolant in oil or VS versa.
I'm out of ideas! Could cam timing be off enough to cause this? I'd assume we would be crashing into valves if timing was off that much. After a brief 1st gear wot and a solid 2 min of idling we popped the hood and the turbo was glowing slightly. Seems to point back to the timing being off... I didn't install the head gasket so I'm not sure any of this is done correctly. Car seems to drive and idle normally. Timing at idle is 12* running a 2g timing map.
I'm stumped...
Basic run down:
6 bolt motor
external gate
No boost leaks.
Good oil pressures.
Factory BOV
I'm stumped...
