Engine Noise / Ticking, Knocking, Tapping MERGED
eric489
Jul 14, 2004
Carson City, Nevada
All threads with vague titles regarding engine bay noises are now merged HERE.
If you honestly feel we can diagnose an internal engine problem from a poor description or low-quality video / audio sample, give it a shot.
I own a 1997 gst spyder and there is a ticking noise comming fron the engine. It comes and goes and it mostly sounds bad at idle. I have 97,000 miles on it and i change the oil regularly. I changed it about 2000 miles ago I need help to fix the problem.
..I'm going to go with ISC. If the battery's been pulled or for any reason the ECU forgets where the ISC is it'll reset the ISC.
haha that definately sounds like your bov. idk it hard to tell through only a video. get under the hood an rev the car with the camera under the hood. we could hear the noise alot better this way.
Not to sound like a broken record but yes, that for sure is a 1g bov. Mine will actually whistle like that for 3 blocks if i hold the pedal just right.. drives me nuts!LOL
It's from mileage, really. The stem seal wears out and leaks, causing the whistle.
I don't understand what you guys are trying to say. Hehehe. I'll dump the BOV but don't have anything but a POS Greddy ebay knock off.
That thing is total crap & isn't set up to be recirculating. What should I go with - any suggestions? GOT to have the noise go away - driving me nuts but its tough to drive when it won't idle. What to get (w/out lots of cash)? Thanks again.
I switched back to the pos ebay greddy knock-off & noise is gone-FINALLY! Thanks so much..
What should I get? Just did rebuild, planning on big 16g but have a 14b that i'm planning on installing till I have ends for the other. The ebay knockoff I'm using isn't set up to recirculate & I'd like to go back to that. Any suggestions on what to get?
I got the starter checked out at autozone and it passed. but they only test to see if it engages. Could it be that the starter is not strong enough while its under a load?
Well my engine starting making a ticking noise so I thought it was my lifters( I have a 2g eclipse) so I bought the 3g lifters. Had them changed (would have done it myself but i am on dialysis) when I picked the car up after the work was done I took off and the noise is still there. I only hear the noise when the car reaches up to 2000rpms. Any other ideas on what it could be. Thanks
The noise that I am hearing sounds like a rapping noise. It sounded to me like the lifters but after having them changed and still hearing the noise it can not be. And like I said before I am only hearing the noise when it gets above 2000rpm's
