Engine help!!!
kriston1987
Sep 22, 2008
San Antonio, Texas
Hello,
I bought a Talon and the engine was shot but I figure I can take it apart and check out what exactly is wrong with it. I'm not really familiar wit doing so but its a project and I think its time for me to learn how to do more with the engine. By the way, the guy said that it lost engine pressure and also that there was a crack in the oil filter housing. Going to be taking the head off today and looking at the block itself. If there is any advice it would be much appreciated. Thanks!
id say you pretty much need to rebuild it if theres low compression and a crack in the oil filter part. When you pull it apart check the head see if theres nothing with it and as for the block look to see if there any crack and you will see oil or antifreez coming out and for the most part just by looking at the piston you will know if there bad or not.
when you say engine pressure what do you mean compression or engine oil pressure?
  • For sale 2g 2G Ignition Cylinder, Key, All Locks
    2G Ignition Cylinder, Key, All Locks $115 + shipping & paypal feesYou must be registered to...
  • For sale 4G63 Buschur Racing Dual Stage Boost Controller
    Buschur Racing Dual Stage Boost Controller $95 + shipping & paypal feesYou must be registered...
  • For sale 1g Griffin Intercooler cores.
    Griffin intercooler cores. Top to bottom flow of course. Very low pressure drop and high cfm...
  • Wanted 2g 2gb Talon / Eclipse -
    Looking for 2gb talon/eclipse. Willing to look at anything.Does not need to be stock, prefer...
    • KCDsmDude
  • For sale 4G63 JE 85.5 mm pistons for a 2.3 L.
    JE part #986E pistons. 85.5mm Quantity of three. 9.5-1 22mm pin. For a 2.3 liter. Good...
