2g Engine swap to Evo 4g63. HELP!
Status
Not open for further replies.
DeadlyAKrunna47
169
31
Jul 9, 2009
Seattle, Washington
Hey im pretty new on here. just got my dream car 3 weeks ago. I want to get a new engine to rebuild for my 98 GSX. This guy is offering me a 2005 Evo 4g63 with only 48k miles on it. He says he can sell the whole engine for $1400.
IS IT WORTH IT?
Also has anyone every done the swap?
Will i need to modify some parts?
Is the Flywheel different? will everything Line up?
Whats the difference between a 6bolt vs 7?
Just forget that idea right now. The evo motor is reversed flow from our engines. Unless youre a master fabricator and have tons of money, its not gonna work.
In my area, I can pick up a running long block for around 300. 1400 for a motor is pretty ridiculous if you ask me.
VFAQ Site - Visual Frequently Answered Questions is a good site to start reading about your car. Theres nothing wrong with your car is there?
1400 for an Evo motor isn't too out of the realm of possibility. My friend Greg just bought a block with a spun bearing for $700 for his Evo. One of the rods in his old block took a vacation the long way; through the transfer case and balance shaft. And block. ;)
But no, the Evo engines don't work in DSMs very well. Everything's pretty much backwards. As for the other questions regarding 6/7 bolt motors, what makes one work in cars designed for the other, etc. etc. a quick search on here, VFAQ, and the tech articles should answer those pretty quickly.
Status
