engine code keeps poping up!
geno414
440
4
Jan 13, 2011
Milwaukee, Wisconsin
hi i really don't know why it keeps popping up i replaced the sensor but the code is 0115 engine coolant temp circuit malfunction and i really don't know to fix it i just put a new pig tail on it and i looked it over and it looks fine why does this keep popping up and also what are these and what do they do .
solenoid activation evap/fps/bcs
Also for the coolant temp circuit you should go look at a wire diagram and find what is all in that circuit of sensors and wires then go check everything that is in line. E.x. If it went from your ecu to a fuse then relay then to the sensor and back to somewhere you need to check all that.
