engine code help
wbrigante
Oct 15, 2011
Brighton, Colorado
Current Fault Log ------------------P0505: Idle Control System P0122: Throttle/Pedal Position Sensor/Switch A Circuit Low Input P0121: Throttle/Pedal Position Sensor/Switch A Circuit Range/Performance engine code help
I have a 96 eclipse l have no vacum leaks no boost leaks, I have put a new gps and idle control motor as well new temp sender. The car will not idle when cold also
Dose any one have any ideas of what else I can check to fix these problems
thanks will give it a try. also when the car is cold it will not fast idle or idle at all were shouls i start to fix that.
tried it no good it will idle rough or it will not idle at all
