Engine Trouble Code... Help!!!
SENCERE
Dec 22, 2004
MIAMI, Florida
I HAVE A 1995 NON-TURBO ECLIPSE.
I Got The Code Po412 When I Scaned The Computer!
Does Any One Know What The Secondary Air Injection Valve A Is???
Because That Is What Has Malfuntioned. The Car Runs Fine.
DOES ANYONE KNOW WHERE IT IS, AND HOW TO FIX IT?
Here it is. This is a description of what it does.
"PULSED SECONDARY AIR INJECTION SYSTEM OPERATION
Only manual transaxle vehicles have a pulsed secondary air injection system. The system injects fresh air upstream of the catalytic convertor. It operates for a short period after cold engine start-up until the engine coolant temperature reaches approximately 5% (125 deg. F). The PCM controls the ground path for the solenoid. When the PCM grounds the solenoid, fresh air from the air cleaner flows through the aspirator valve to the catalytic convertor. The aspirator valve prevents exhaust gases from flowing into the fresh air stream, at the air cleaner when the solenoid is grounded. If the aspirator valve malfunctions, a popping noise could be heard during cold start throttle stabs.
The secondary air injection system contains:
1. Pulsed secondary air injection valve
2. Pulsed secondary air injection solenoid
3. Connecting hoses and tubes"
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
