Trouble Code help??
2g_DSMer
181
Oct 1, 2008
The Lake, California
Not too long ago I installed an mbc and my check engine light came on so I checked to see what it was and the code that came up was P1103 (Turbocharger Wastegate Actuator).
So my question is what can I do to bypass this with out having the check engine light come back on or did I maybe install something wrong??
Thanks
That illustration has FAIL written all over it. You want to run your boost source from either the Jpipe on an MHI turbo or from the compressor housing nipple if your still on the T25 connect this line (boost source) to the MBC then from the MBC to your WGA wastegate actuator.
hey thanks a lot man ill give that a try
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
