trouble code p1103
gsx4357
103
Sep 26, 2010
maricopa, Arizona
ok so i did a run on my car yesturday and it seemed like it kept getting fuel cut once my foot was to the floor...i must of hit it like 4 or 5 times...today i noticed a p1103 code which is turbocharger wastegate actuator malfuncion...if the fuel cut hit to many time could it set that code off? never had a problem with it before...any ideas"?
Never have worked on a car with a turbocharger in it. But let me look on my Mitchell real quick.
From what my resource tells me you need to check your waste gate actuator. It is telling me that you need to run a pressure test in 2nd gear. But all the test is doing is checking the pressure of the waste gate. So like I said check out that actuator. It could be causing you your code.
hitting fuel cut can trigger this code your wastegate solenoid or boost control is what keeps you from hitting fuel cut so if the boost pressure raises above 16psi the ecu will see this as your wastegate solenoid malfunction just reset the ecu and dont hit fuel cut! this will happen more often when its cold out if your car is not tunned
  • For sale 4G63 6 Bolt Kiggly Modded Oil Pump Pickup
    6 Bolt Kiggly Modded Oil Pump Pickup $95 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G OEM Carrier Bearing
    NEW 1G OEM Carrier Bearing $115 + shipping & paypal fees* these are $165 onlineYou must be...
  • For sale 2g NEW 2G OEM Timing Belt Tensioner Arm
    NEW 2G NEW 2G OEM Timing Belt Tensioner Arm $45 + shipping & paypal fees* these are $70 online...
  • For sale 1g 3 Bar MAP Sensor & Mounting Bracket
    3 Bar MAP Sensor & Mounting Bracket $55 + shipping & paypal feesYou must be registered to see...
  • For sale 1g NEW 1G ECM Link Speed Density Harness
    NEW 1G ECM Link Speed Density Harness $45 + shipping & paypal fees* these are $65 online * I...
