help...check engine crankshaft code?
varGST
Sep 26, 2004
Flanders, New Jersey
my car is running check engine code PO335.
"crankshaft position A curcuit sensor malfunction"
Can someone please help me understand what this
means and if it's fix is easy or difficult. :confused:
Well, first of all, you're in the NON-TURBO (420a motor) Section buddy. So, we basically have different motors/set-up..
Nonetheless, we both share pretty common things as far as universal terms go...
The problems is your CPS sensor. This is a very simple fix. You just need to pull out a plug looking thing, and replace it with a new one.
The crank is not lined up properly, therefore your car will not kick over in a proper manner. Is it even running right now? Or no start? I'd be surprised if it ran with a faulty CPS...
