BrokeTurbo
- 47
- 0
- Sep 4, 2002
As the following thread will illustrate, motor break-in is not the issue it was in the fifties and sixties.
For all intents and purposes, your method will not significantly matter, within reason.
Well, I am getting the laser back from the shop this weekend. Here's a List of whats new, and whats not.New Pistons, Bearings, Rods, Crankshaft, Rings, Oil pump, Belts, Pullys, Head, Valves, No balancer belt. The only real thing thats old, but freshened up is the block, and valve cover, and the FI system. (Fuel Injection)
I am going to run Mobil 1 10w-30 with a Puroilator PL101xx Filter. I have a new clutch with a resurfaced flywheel going on. I've also got new fluids in the transmission.
My question is how should I break it in? This is my first non 70's Chevy, and I was wondering if there are any tricks to it.
The way I was going to do it, was 15 min of idle, warm up. Make sure all fluids/hoses/electrical is plugged in. Then about 1 hour of normal driving. Might take out to the Highway, and cruise around 65-70 for a little bit.
This sound good? I was not going to get on it, or push it till ive got about 500 miles on the engine. Even then, I'll still be taking it easy. Anyone have any tips or help? Thanks
Good luck & Happy Boosting!
