athlete3344
- 450
- 124
- May 1, 2010
Tampa,
Florida
Good evening,
Im currently in the process of blueprinting my block, and Ive finished up the main journal oil clearances. Goal for now is to support a 20g and have a fun to drive car. Based on the data, I do have a few questions:
y = vertical main measurement (parallel to cylinder)
x = horizontal main measurement (other way to cylinder)
Also for fun I grabbed some measurements with the original bearings. Looks like #3 was still showing some taper, and maybe #2 and #1 were wearing a little faster. #5 and #4 look to be pretty close to the new ACL bearing measurements above. Also egging was a bit worse in #3, 2, and 1.
- Overall, things look great, but Im wondering if I should be picky about #4, 3, and 2 oil clearances? I dont mind spending a little extra on a line hone if its worth it w/ the above goals in mind.
- Plastigauge and dial bore mostly agree on taper for #4. I do think my dial bore/mic error is in the 0.0005 range, so the difference make sense. Also for #4 and #3 the plastigauge was just a hair outside the 0.0020 range.
- Is it normal for these bearings to be egg shaped? I saw this mentioned in a Jafro video but wanted to double check.
- Other machine work Im looking to include is a bore/hone for new pistons, fitting 1g rods to new pistons, deck, cleaning/hot tank, and crankshaft galley ball removal (maybe rod work depending on clearances but Im expecting them to be spot on). Is there anything else I should be asking for to get the block ready to start my build?
| oil clearances w/ new acl bearings | 5 | 4 | 3 | 2 | 1 |
| y1 | 0.0025 | 0.0024 | 0.0019 | 0.0024 | 0.0023 |
| y2 | 0.0025 | 0.0024 | 0.0018 | 0.0026 | 0.0024 |
| x1 | 0.0034 | 0.0031 | 0.0032 | 0.0031 | 0.0030 |
| x2 | 0.0033 | 0.0031 | 0.0030 | 0.0032 | 0.0027 |
| plastigauge | 0.0020, no taper | 0.0018-0.0019, no taper | 0.0019, no taper | some slight taper 0.0018 <-> 0.0019 | 0.0020, no taper |
| oil clearances, original bearings | 5 | 4 | 3 | 2 | 1 |
| y1 | 0.0026 | 0.0025 | 0.0025 | 0.0029 | 0.0027 |
| y2 | 0.0028 | 0.0025 | 0.0023 | 0.0029 | 0.0029 |
| x1 | 0.003 | 0.0029 | 0.0037 | 0.0041 | 0.004 |
| x2 | 0.0029 | 0.0031 | 0.0034 | 0.004 | 0.0039 |
