Emissions question...
Status
Not open for further replies.
Hi all,
I'm new to the fourms... First let me introduce my self... I have a 87 Turbo supra with a 2.5 Twin turbo 1jz engine in and twin k26's onboard... should be good for 550 rwhp.... My last setup was 7mGTE 3.0 with a 63MM turbo and made 454 RWHP.....
Anyways, I'm in the process of picking up a 93 talon with a JDM engine and a rebulit trans. Car has HKS 272's, atc 2600 and 3", and walbro pump.
Thing is dog slow at 15 PSI, partly because of a stock turbo and huge cams and I believe a knock sensor maybe bad.
I know one of the CYL's has low compression 120 but the rest are 150.... (going to test my self before I buy)
To the point... I wondering if I'll be able to pass emissions with 272's? I know he was able to pass with the 3" and the cat but now with the addition of the 272's I know the idle will be hard to pass.... and since they only do the idle test for 4wd here it's what I'm most worried about..
Anyone have tips on passing? Or if it's even possible to pass with 272's?
Thanks,
Maybe the type's not big enough.
Perhaps the message is just too cryptic.
Surely it's not from ignoring the rules.
But whatever the failing, mine or yours,
Closed.
Status
