flywheel question
Any time you resurface a flywheel the step height at least needs to be checked. The actual step height needed varies between manufacturers, but if I'm not mistaken Exedy works with the factory step height. I'm sure if you contact a vendor like STM or ExtremePSI, or the manufacturer directly, they'll be able to tell you what the proper step height is for that clutch kit.
