tschuhly
- 230
- 70
- Nov 6, 2024
York,
Pennsylvania
Hey everyone,
This is my first project car, and I am nearing the end of it, but I have the dreaded electrical gremlins that are keeping me from saying its complete. I am waiting for my base tune to come back from JK Tuning in Carlisle, PA so I am unable to start the car, but I have switched the key to the on position and found these issues. I am fairly new to all of this so any help is appreciated.
I have already checked all fuses and went through all of the main harness ground points and ensured that they were clean and metal on metal. I also have an after market radio (Kenwood). I am going to post all problems here because I am unsure if they are related.
1. Dash lights always on regardless if the switch is on or off.
2. Tail lights always on
3. Fog lights not working
4. Left turn signal fast (missing right side marker socket).
5. Right turn signal slow (")
6. Front headlights don't work (low/high)
7. Horn (I can hear something engage so I am fairly certain it is just the horn.
8. Hazards don't work
9. Buzzing with dimmer switch when black/yellow wire is connected to radio plug and radio is grounded. When disconnected, dash lights don't work at all but buzzing goes away. The thing that is weird is the pin that it is connected in on the plug doesn't have anything on the radio side of the plug that connects to it. I have taken the switch apart and nothing looks off.
10. High pitch noise when on from radio almost like a dog whistle (different noise than previous).
11. Handbrake light stays on
Thank you guys so much!!!
). I believe when I unplugged the radio the dash lights didn't work at all. I then saw the orange/white wire that was labeled dimmer on the back of the radio so I tried to wire the black/yellow to that and the dimmer seemed to work for the radio, but the dash still didn't work so I undid that. I tried to be sure that I followed the wiring diagram that came with the radio and matched it up to the adapter for the car that was already there when I bought it.
