2G Having some electrical issues
Dirtbike29
134
16
Mar 10, 2024
Surrey, BC, Canada
I have power going in to my fog light switch but none going out of the 2 wires under 12volt in is it the switch or could it be this passing control relay
My fog lights, dash, oil pressure gauge, and high beam indicator don’t work. Would those all be on the same circuit? The high beams work but not the dash blue indicator.
The fog light has 12v but it’s not powering the fog lights, switched the fuse box relays around no different.
My alarm system might be disconnected causing my issue but if someone can confirm idk anything about the light wires. It's hard to find information. I jumped the switch everything I noticed my ASD relay is boot leg may be part of it because I don’t have the key fob.
