Electric issues help pls
Adriano1GbGS-T
Feb 5, 2022
Argentina, Alabama
How are people doing, they are having some electrical problems, nothing works on the driver's side, no mirrors, no speakers, but the most important thing is that abs stays on after turning off the car and I have to disconnect the battery so that it turns off, and sometimes When I plug it back in it turns on by itself. Is it a common problem?
I attached a photo with an orange circle of what is apparently on
You have two separate problems. For the door controls, since none of the buttons work in the door, check two things: 1) The driver's door harness plug under the dash, near the door hinge, to make sure it didn't become disconnected, and 2) if that is securely plugged in, take the door trim panel off and make sure that your ground wire didn't get disconnected/broken off. If it is still connected, use an ohm meter to test and see if there is a ground connection to the body metal (like bare metal under the dash).
There are great resources on here showing the wiring diagrams for your car. These will show you what color wires should control what device and where they are connected.
As for the antilock brake module, others can speak about it more knowledgably, but maybe unplug the unit until you can get it tested to see if it is broken, or got damaged.
