EGR valve Gasket?
Cgillies86
59
Dec 22, 2004
Rochester Hills, Michigan
Today I was removing my EGR and installing a block off plate, and when I removed the EGR I noticed there was no gasket. Is there supposed to be an EGR gasket?
karbon said:
I have one on my 2g, I even got it at the autoparts store. If you want one, don't hesitate to cut one out of some gasket material.
I did the same thing. I wouldn't trust a block off plate to seal properly against the intake manifold. Mine leaked quite a bit until i installed a home-made gasket.
Just use some high temp RTV sealant for a gasket. I've used it for EGR valves on plenty of different cars with no leaks whatsoever.
