EGR valve and vaccums
Levesque
152
Apr 19, 2009
Chicoutimi, QC, Canada
About to finishing plugging everything in my 6 bolt swap. Must the EGR vaccum ( line coming out of the egr) be plugged or can i block it ? Like Vaccum line with a screw in it for now ?
What about the 3 on top of the TB? That go to the soleniod. Can i do the same to those?
I have a DSMlink if that matters :D
Thanks alot.
when i blocked off the nipples on my tb, i just took a piece of hose and looped it between two of them, saves from having to use a bunch of block of pieces.
I built a block off plate and used a litle gasket maker on it, left the 2 ports on the egr unblocked (plates blocking it) and capped off the ports on TB napa had a little cap set for $5 so i picked up 2 packs and took off all vacuume lines on it, Got to say car does like starting up softer now. you can pm me for any questions i just did this yesterday =]
When I did my blockoff, I did have an actual blockoff plate that I tagged from a 1.8L motor from a yard.
With the bolts long enough on the stock EGR, I just sandwiched the plate inbetween the EGR and manifold with gasket material facing the manifold.
Aluminum can material is great as well - easy to trace on and cut with scissors..
