mac 108
- 213
- 3
- Feb 15, 2005
Memphis,
Tennessee
My car is a 90 AWD with a 2G blackbox flashable ECU.
Right now I cannot get ECUflash to communicate with the ECU. I have tried two different laptops, one using Win 7 and one using Win XP with no luck.
I have vehicle set to 96-01 Mitsu All 2nd Gen. I am using a Tactrix Openport 2.0 cable.
Win XP Laptop
[23:58:59.171] EcuFlash Version 1.44.4503
[23:58:59.171] OS Version Windows XP
[23:58:59.171] Kernel Type winnt
[23:58:59.171] Kernel Version 5.1.2600
[23:58:59.171] CPU i386
[23:58:59.171] Product Name Windows XP
[23:58:59.171] Product Type windows
[23:58:59.171] Product Version xp
[23:58:59.171] Qt Version 5.4.0
[23:58:59.187] 67 memory models read.
[23:58:59.187] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[23:58:59.359] 747 ROM metadata models scanned.
[23:58:59.359] checksum module "subarudbw" loaded.
[23:58:59.359] checksum module "subarudiesel" loaded.
[23:58:59.359] checksum module "mitsucan" loaded.
[23:58:59.359] checksum module "mitsuh8" loaded.
[23:58:59.359] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[23:58:59.359] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[23:58:59.375] using metadata XML ID read_evo5 from file C:/Program Files/OpenECU/EcuFlash/rommetadata/read templates/read_evo5.xml
[23:58:59.375] flashing tool "wrx02" loaded.
[23:58:59.375] flashing tool "wrx04" loaded.
[23:58:59.375] flashing tool "sti04" loaded.
[23:58:59.390] flashing tool "sti05" loaded.
[23:58:59.390] flashing tool "mitsucan" loaded.
[23:58:59.390] flashing tool "mitsukernel" loaded.
[23:58:59.390] flashing tool "mitsukernelocp" loaded.
[23:58:59.390] flashing tool "mitsubootloader" loaded.
[23:58:59.390] flashing tool "shbootmode" loaded.
[23:58:59.390] flashing tool "shaudmode" loaded.
[23:58:59.390] flashing tool "subarucan" loaded.
[23:58:59.390] flashing tool "subarucand" loaded.
[23:58:59.390] flashing tool "subarubrz" loaded.
[23:58:59.390] flashing tool "subaruhitachi" loaded.
[00:00:42.093] using metadata XML ID read_evo5 from file C:/Program Files/OpenECU/EcuFlash/rommetadata/read templates/read_evo5.xml
[00:00:42.125] J2534 API Version: 04.04
[00:00:42.125] J2534 DLL Version: 1.01.4500 Jun 26 2015 15:08:08
[00:00:42.125] Device Firmware Version: 1.15.4474
[00:00:42.125] Device Serial Number: TAQocN*a
[00:00:49.359] sending init sequence 2
[00:00:51.375] interface close
Win 7 Laptop
[13:58:42.804] EcuFlash Version 1.44.4503
[13:58:42.804] OS Version Windows 7
[13:58:42.804] Kernel Type winnt
[13:58:42.804] Kernel Version 6.1.7601
[13:58:42.804] CPU i386
[13:58:42.804] Product Name Windows 7
[13:58:42.804] Product Type windows
[13:58:42.804] Product Version 7
[13:58:42.804] Qt Version 5.4.0
[13:58:42.819] 67 memory models read.
[13:58:42.819] scanning for metadata models in C:/Program Files/OpenECU/EcuFlash/rommetadata
[13:58:48.669] 747 ROM metadata models scanned.
[13:58:48.669] checksum module "subarudbw" loaded.
[13:58:48.669] checksum module "subarudiesel" loaded.
[13:58:48.669] checksum module "mitsucan" loaded.
[13:58:48.669] checksum module "mitsuh8" loaded.
[13:58:48.669] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[13:58:48.669] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[13:58:48.685] using metadata XML ID read_evo5 from file C:/Program Files/OpenECU/EcuFlash/rommetadata/read templates/read_evo5.xml
[13:58:48.685] flashing tool "wrx02" loaded.
[13:58:48.685] flashing tool "wrx04" loaded.
[13:58:48.700] flashing tool "sti04" loaded.
[13:58:48.700] flashing tool "sti05" loaded.
[13:58:48.700] flashing tool "mitsucan" loaded.
[13:58:48.700] flashing tool "mitsukernel" loaded.
[13:58:48.700] flashing tool "mitsukernelocp" loaded.
[13:58:48.700] flashing tool "mitsubootloader" loaded.
[13:58:48.700] flashing tool "shbootmode" loaded.
[13:58:48.700] flashing tool "shaudmode" loaded.
[13:58:48.700] flashing tool "subarucan" loaded.
[13:58:48.700] flashing tool "subarucand" loaded.
[13:58:48.700] flashing tool "subarubrz" loaded.
[13:58:48.716] flashing tool "subaruhitachi" loaded.
[13:59:05.678] using metadata XML ID read_evo5 from file C:/Program Files/OpenECU/EcuFlash/rommetadata/read templates/read_evo5.xml
[13:59:05.693] J2534 API Version: 04.04
[13:59:05.693] J2534 DLL Version: 1.01.4500 Jun 26 2015 15:08:08
[13:59:05.693] Device Firmware Version: 1.15.4474
[13:59:05.693] Device Serial Number: TAQocN*a
[13:59:13.103] sending init sequence 2
[13:59:15.116] interface close
I can get my handheld OBDII code reader to read and erase codes properly.
I can also get EvoScan to connect and datalog with the OBDII 96-05 or Mitsu MUTIII boxes checked.
If I check DSM/3000GT/Eclipse MUTovrOBDII, I get a J2534 error.
What am I doing wrong?
Win XP Laptop
Win 7 Laptop
