ECUflash Blackbox ceddy - basetune for new turbosetup
ChristianEclipseAuto
5+ Year Contributor
137
9
Apr 6, 2018
Roskilde, Europe
Hi everyone
Can anyone help me with a basetune for my DSM on the blackbox ECU.
I have installed ceddymods and got the car running with 560cc injectors.
My turbo is the stockish t28 from Forced Performance and we changed the actuator to the stock one from the t25 so it could run lower boost. The boost is set to 7 psi on the gauge.
I need a base tune for the t28 so I can get it tuned on Dyno. Is there anyone here who might have the same setup there can help me ?
Thanks a lot. I did install everything, when changing the injectors scaling it does say 565 and not 560. I guess this i normal. The car idles fine, no issues there. And it runs fine when driving Down the street. I have not get tuned the WOT and I am Only running 7 psi on the t28 turbo.
When I open octane fuel Maps 1 it goes Down to 9,5 in some of the areas. Should I change the last 4 areas/vertical to 10,5 or have some one done something difference when tuning the WOT ? Just want to be sure ?
If you have no way of monitoring the AFRs with a proper wideband, you shouldn't be adjusting the fueling parameters in any parts of the map. The resolution of the global injector scaling shouldn't even be a concern, but you're adjusting it without having a way to log the important items you need to, you should take it to someone to tune it for you, or pay for a remote tune (Which they won't do it if you don't have a proper wideband calibrated AND have EvoScan logging setup)
I have an afr gauge installed with integrated boost control from innovate. Which is set to Only 7 psi.
I also have set a computer up for evoscan and log. The Only thing I am missing is Maybe a SD card for the tactrix to log while driving.
The injectorsscaling is set to be 565 and the latancy is 0.048 as shown.
Okay, so I dont have to change the last 4 lines to 10,5 in the octane fuel Maps 1 in ecuflash or ?
I highly suggest you do some reading on basic WOT tuning and the setup prior-to doing pulls. There's more than a couple decent guides on DSMtuners floating around
I tried to set up everything as shown in the link you send earlier.
I have setup the last 4 columns to set 10.5 in the AFR in ecuflash for the WOT.
But are there any links about WOT you suggest I check because I cant seem to find any in the ecuflash ?
I would argue you're not trying very hard, there's over a decade worth of content that's ecuflash specific, let alone tuning general.
