ECU Options???
918_gsx
127
May 1, 2011
tulsa, Oklahoma
Ok, I have a 92 GSX. Wasn't getting power to my #1 injector BEFORE the resistor box so I figured probably something in the ECU went bad. Pulled it and sure enough a cap has leaked everywhere. Just curious as to what ECU other than another GSX ECU would work for me. Thanks.
If its a 5spd I, don't see why a GST ecu wouldn't work. If its a automatic, then you would need a GSX ecu..... Pretty much what it comes down to.
The ecu doesn't send power to the injectors. All 4 injectors should see 12v at one pin of their connector, when the key is in the on position. They are opened by the ecu grounding the other pin.
I know. I have another thread on this. So I was kinda wondering if the area on my ECU that's showing the leakage is the area for ground to injectors...I can start the car and pull injector 2,3,4 and the car will die. I pull #1 with car running and there's no change, stays running, like crap of course.
