Cox Abele
- 485
- 56
- Jul 4, 2010
Roanoke,
Virginia
I am fairly certain that I have bricked my ECU. I am in need of another for my 98 Spyder. I have my old tune saved, so I should be able to reflash everything back without an problems.
In looking for a replacement ECU, I see that ceddy suggests there is a difference between the Spyders and the coupes:
The way this is written, it's not clear. Can I flash my Spyders tune to a coupe and expect it to work, or will I be dealing with fuel pump module issues? Do I need an h8 ECU out of a spyder?
Notes
All DSM Turbo Ecus are compatible Flash wise.
A 98 ROM can be Flashed to a 99 Ecu, and vice versa.
Also a GST ROM can be Flashed to a GSX ECU, and vise versa.
98-99 Spyder Ecus are compatible Flash wise.
The only hardware difference with the Spyder Ecus, is the Fuel Pump Pin.
The Spyders output +5v to turn on the Fuel Pump Module.
While the DSM pull +12v to ground to turn on the Fuel Pump Relay.
Testing so far has revealed that all Ecus with the same PCB Code are compatible, Flash wise.
The Evo5/6 are not compatible(different PCB Code), and Flashing an Evo image to a DSM Ecu will brick it.
(Dont ask how I know)
